zefreak Posted December 15, 2021 Share Posted December 15, 2021 I followed the instructions for setting up the program and everything seems to be working at first - all of the routes and trains are visible in the RW software. However, when I go to a scenario and click Start the game loads but when I load the scenario I only see the standard TS2021 UI and there are no enhancements or custom menus Quote Link to comment Share on other sites More sharing options...
RW Central Posted December 15, 2021 Share Posted December 15, 2021 Hello @zefreak, just sent you a private message so we can collaborate and find the cause of this issue happening for some users Quote Link to comment Share on other sites More sharing options...
RW Central Posted December 17, 2021 Share Posted December 17, 2021 Issue is solved. Quote Link to comment Share on other sites More sharing options...
robin2773 Posted December 28, 2021 Share Posted December 28, 2021 Bonjour, j'ai le même problème, pourriez vous partager la solution ? ------- Hello, I have the same issue, could you share how you fixed it ? Merci Quote Link to comment Share on other sites More sharing options...
RW Central Posted December 29, 2021 Share Posted December 29, 2021 Bonjour Robin, Il faut passer le mode d'affichage dans les option TS en plein écran fenetré (borderless) au lieu de plein écran simple dans les options de Train Simulator. Le support du plein écran avec RWE 2 ne fonctionne pas encore pour tout le monde. Quote Link to comment Share on other sites More sharing options...
robin2773 Posted December 29, 2021 Share Posted December 29, 2021 Je suis en borderless et toujours rien ne s'affiche J'ai mis le log en Pj debug.log Quote Link to comment Share on other sites More sharing options...
RW Central Posted December 29, 2021 Share Posted December 29, 2021 Merci, nous allons vous recontacter par message privé d'ici peu pour résoudre ce problème. Quote Link to comment Share on other sites More sharing options...
loud06 Posted January 1, 2022 Share Posted January 1, 2022 bonjour j'ai le même soucis en lançant par exemple le scénario "busy day on the coast sur la route Riviera Line, rwenhancer et ses menu et hud n'apparaissent pas, j'ai bien mon écran paramétré en borderless... merci Quote Link to comment Share on other sites More sharing options...
David Hutchinson Posted September 7, 2022 Share Posted September 7, 2022 Hello, I have the same problem , everything was fine yesterday now Today no icons showing am using borderless screen mode, would it have anything to do with last update. Merci. Quote Link to comment Share on other sites More sharing options...
David Hutchinson Posted September 27, 2022 Share Posted September 27, 2022 I am having this problem again no speedo , no icons or voices , seems to happen after a windows update. Merci Quote Link to comment Share on other sites More sharing options...
Scip Posted October 15, 2022 Share Posted October 15, 2022 i have this now to the rw2 ui shows up for 1 sec and then disapears i cant start the service Quote Link to comment Share on other sites More sharing options...
gaugeglass Posted May 3 Share Posted May 3 Hi, I am having the same issue with no speedo , no icons or voices , I have just installed RW enhanced 2 onto my new Win 11 computer. Everything seems to be showing and working OK until the scenario opens and the rw2 ui shows up for 1 sec and then disappears (as if going behind the Sim screen), the scenario will run, but with no enhanced effects. I have just checked and it is working fine on my old Win10 computer, can anyone help me sort this out? Quote Link to comment Share on other sites More sharing options...
Aldred Posted June 8 Share Posted June 8 I'm having the same issue - repeatedly. Anyone have ANY answers for this? Quote Link to comment Share on other sites More sharing options...
steph78 Posted June 9 Share Posted June 9 Bonjour, j'ai eu le même problème il faut veiller a installer RW2 sur le même chemin de base que TS, (C):\Program Files Quote Steph78 https://www.youtube.com/channel/UC4YY-6Y2mMs-L2lTodO2jwg Link to comment Share on other sites More sharing options...
Aldred Posted June 9 Share Posted June 9 @ steph78 Thanks. I'll let you know how I get along. 1 Quote Link to comment Share on other sites More sharing options...
