DecrepitTSfan Posted December 14, 2023 Share Posted December 14, 2023 (edited) Greetings, Months ago, the PC on which TSC is installed developed unrecoverable Win10 boot partition corruption. Win10 had to be installed from scratch. That done, I first reinstalled Steam, then used it to reinstall TSC. That done, I called myself installing all RWE2 pre-requirements, then overwrote new TSC install with my heavily modded pre-Win10 corruption-TSC/RWE2 directory, assuming all would work as intended. It did, except for RWE2. RWE2 would get partway through cooking, then exit. Following printed guidelines, I uninstalled then reinstalled RW2, twice, the second time in a different directory. No change. RW2 did not complete cooking. After a few more attempts, I gave up and left the matter alone. Recently, (April/May 2024), seeing that a new update was available, I launched RWE2 and had the program update itself. That done, it still does not cook. In fact, it doesn't get as far along with cooking as it did pre-update before giving up the ghost. (Not that that matters.) A thing I notice while reading debug.logs is that "serz" or "serz.exe" is mentioned just prior to the long beginning its close-down sequence. Here are the two "ERROR" lines from my most recent debug.log: 2024-04-29 13:10:34.197 ( 4.930s) FileSystem.cpp:549 ERR| Could not SERZ '"O:\SteamLibrary\steamapps\common\RailWorks\Content\PlayerProfiles.bin"' file. Error code: -1073741701 2024-04-29 13:10:34.197 ( 4.930s) Settings.cpp:941 ERR| Can't convert TS settings data from bin to XML Whether the about points to the source of my issue, or I somehow failed to install a pre-requiring, which I doubt but won't rule out, I'm stumped. Any help is most appreciated! Entire debug report is attached. debug.log Edited May 12 by DecrepitTSfan re-writing of original for better clarity Quote Link to comment Share on other sites More sharing options...
DecrepitTSfan Posted May 12 Author Share Posted May 12 OP here, to say that the original post seen above has been totally rewritten, to hopefully make my RWE2 dilemma more understandable. Thanks for your consideration. Quote Link to comment Share on other sites More sharing options...
