milko80 Posted August 24, 2022 Share Posted August 24, 2022 Hello, Recently I have to adjust the graphics settings every time before I can play. These settings are somehow no longer saved. Certain settings (such as Vulcan on/off) are saved when closing. I also suspect that the shader adjustments are no longer implemented, especially the DOF settings. I don't see any difference between 1 and 1000. What can I do to fix this? Quote Link to comment Share on other sites More sharing options...
RW Central Posted August 24, 2022 Share Posted August 24, 2022 Hello @milko80, Can you tell me which kind of settings are not saved ? Quote Link to comment Share on other sites More sharing options...
milko80 Posted August 24, 2022 Author Share Posted August 24, 2022 (edited) It concerns the settings below. These are the desired parameters. Train Simulator then also starts with these settings. However, after closing RWE, the following parameters are set again and I have to adjust them again to the desired one. Edited August 24, 2022 by milko80 Quote Link to comment Share on other sites More sharing options...
milko80 Posted September 10, 2022 Author Share Posted September 10, 2022 This problem is solved by reinstalling RWenhancer and deleting the user configuration setting file. https://www.rwcentral.com/topic/1839-clean-deinstallreinstall-rw-enhancer-2/ Quote Link to comment Share on other sites More sharing options...
RW Central Posted September 10, 2022 Share Posted September 10, 2022 Glad that this issue is solved, must have been a file corruption of the settings.xml file 1 Quote Link to comment Share on other sites More sharing options...
