illige Posted April 17, 2023 Share Posted April 17, 2023 Using Enhancer 2 I have the problem that there are White lines in the transition to the sky, about all if the sky is dark. Quote Link to comment Share on other sites More sharing options...
462 Posted April 20, 2023 Share Posted April 20, 2023 (edited) This was an issue quite awhile back and was resolved in an update after some discussion - unfortunately I cannot find the thread ATM! Perhaps some one else could point you in the right direction? It was originally fixed in an update as below in the next item I have posted: Edited April 20, 2023 by 462 Quote Link to comment Share on other sites More sharing options...
462 Posted April 20, 2023 Share Posted April 20, 2023 (edited) Click the update number above - hopefully You just require the update - then perhaps in certain circumstances it has returned with the latest DTG core update tinkering! Edited April 20, 2023 by 462 Quote Link to comment Share on other sites More sharing options...
RW Central Posted April 20, 2023 Share Posted April 20, 2023 Hello, Yes this issue is present in the base game and much more visible when using Vulkan/DXVK. It was fixed by RW Enhancer 2 some time ago but if you are using the AP Sky & Weather 2.0 the bug is back (since AP Sky & Weather 2.0 replace the shader that RW Enhancer 2 is fixing). So I can't do much about this. Quote Link to comment Share on other sites More sharing options...
