Queenfan1976 Posted September 30, 2022 Share Posted September 30, 2022 Morning all / Bonjour.... Has anyone else had problems after downloading the new update and then cooking TS files? One the cooking process has finished, the programme closes and I'm back at my Desktop. Do I need to re-download and install RW Enhancer 2 and start fresh? Thank you / Merci Justin Quote Link to comment Share on other sites More sharing options...
RW Central Posted September 30, 2022 Share Posted September 30, 2022 Hello @Queenfan1976, Which version of RWE 2 are you using currently ? There been some issues introduced with the 0.8.2.0 version but it has been reported as fixed in the 0.8.2.2 hotfix released yesterday evening. Quote Link to comment Share on other sites More sharing options...
Loufreisfreeway Posted October 1, 2022 Share Posted October 1, 2022 Yes i have completely lost a route..it was available before the recent update.it is not on the routes atall?? it is however there in my TS game..but not if i use RWE 2..it was there up and until this update..so it appears since the update its not being cooked like it was before..?? Quote Link to comment Share on other sites More sharing options...
RW Central Posted October 1, 2022 Share Posted October 1, 2022 @Loufreisfreeway Can you perform a "Reset" in the content cooker and send your "debug.log" file (in RWE 2 installation directory) ? Quote Link to comment Share on other sites More sharing options...
Queenfan1976 Posted October 2, 2022 Author Share Posted October 2, 2022 All working fine now with no loss of files or routes Quote Link to comment Share on other sites More sharing options...
Loufreisfreeway Posted October 3, 2022 Share Posted October 3, 2022 Hi..i did the reset as advised,the route is still missing..however it IS in the route selection ( and ticked) at the cooking stage,its just not in the routes at the Drive stage..tested it just with TS..and working fine..i shall send the log report. Quote Link to comment Share on other sites More sharing options...
Loufreisfreeway Posted October 3, 2022 Share Posted October 3, 2022 have forwaede the de bug file debug.log Quote Link to comment Share on other sites More sharing options...
RW Central Posted October 3, 2022 Share Posted October 3, 2022 As I was thinking, there is an issue in a track tile blueprint file for this route. You can view this in the debug log file: FileSystem.cpp:569   ERR| Could not SERZ '"C:\Program Files\RW Enhancer 2\Cooking\Temp\8f6b8f62-804d-4444-a488-c3b69dd87e45\Networks\Track Tiles\-000066-000039.bin"' file. Error code: 259 TSContentCooker.cpp:11499  ERR| XML parsing error in 'C:\Program Files\RW Enhancer 2\Cooking\Temp\8f6b8f62-804d-4444-a488-c3b69dd87e45\networks\track tiles\-000066-000039.xml' file at line 7582. Error Description: Start-end tags mismatch This error is caused either by the route maker or by the "SERZ.exe" tool made by DTG in order to convert .bin files to readable .xml files. So RWE 2 is not causing this issue. With the latest version of RWE 2, routes with such errors are not loaded by RWE 2 anymore. that's why you can not see it anymore. In the near future, I will try to add a system to force route cooking even if an error is detected in the blueprint files. But for now routes with such errors are not loaded anymore in order to prevent various potential issues. Thank you for your understanding and patience until a good system is found as a workaround to this kind of issues  Quote Link to comment Share on other sites More sharing options...
Loufreisfreeway Posted October 3, 2022 Share Posted October 3, 2022 Hi,thanks for your prompt reply,and information on the reason,i didnt realise it had an error,( as it plays 100% ok) and was before the update,but its good that its not overlooked by RWE2..a workaround would be good if possible at a future date..as i love this route..thanks again for your quick responce for my issue.. Quote Link to comment Share on other sites More sharing options...
