xim Posted February 3, 2023 Share Posted February 3, 2023 Hearing from other places RW enhance 2 causing major problems with TSC? Not seeing much out of the usual on this forum. Vocal minority? Heavy moderation here? Fancy this thing, but not if it messes up TSC cheers Quote Link to comment Share on other sites More sharing options...
FoxDelta99 Posted February 6, 2023 Share Posted February 6, 2023 Hi Xim, I've been using RWE2 for more than 6 months now, and I've not faced any issue so far. Only hiccup was when I migrated my files from my old computer to my new one. But then the developper helped sort it out, and it was resolved in less than a day. So, so far, I'm 100% satisfied of RWE2. 1 Quote Link to comment Share on other sites More sharing options...
RW Central Posted February 6, 2023 Share Posted February 6, 2023 Hello @xim, When it was just released they were some issue yes, the "cooking" process could mess up some files when the user for example installed RWE 2 in the TS (railworks) installation directory, which is a bad thing to do, RWE 2 should not be installed in the railworks directory but should be installed anywhere else on the computer like any other regular software/game. Since the release a lot of work has been done to prevent issues and I have not received reports of any major breaking issue since a lot of time now (more than 1 year). The cooking system is not modifying/deleting any TS assets files it is just a file reading process. The only files that are modified are the engines scripts files (this is mandatory for RWE 2 to work correctly and some TS addons like the "cobraone raildriver and joystick interface" use the same exact method) but they are not modified all at once. When you launch a driving session with RWE 2, only the script files related to the engine you want to drive are modified and once your driving session is ended, scripts files that were modified by RWE 2 are restored in their original state each times. If you want to be 200% safe I always recommend to make some regular backup of your Railworks install directory anyway if you can, this is a good practice before any TS major addon/assets installation not just for RWE 2 If you have some other questions, feel free to contact me by private message ! Also thank you for your comment @FoxDelta99 ! 3 Quote Link to comment Share on other sites More sharing options...
Loufreisfreeway Posted February 8, 2023 Share Posted February 8, 2023 Ive had this amazing addon for over a year now..and ive not had any issues,i did have a few issues at 1st,however it was with TS itself and not this software,i had to do a few small tweaks within TS..i have a mid range PC.( which is needed anyway to play TS at a realistic level).i can highly reccomenmed this addon,an exellent support team aswell.. 1 Quote Link to comment Share on other sites More sharing options...
Spamcan Posted February 8, 2023 Share Posted February 8, 2023 Agreed 1 Quote Link to comment Share on other sites More sharing options...
ighten Posted March 30, 2023 Share Posted March 30, 2023 Just installed.. no issues at all and never mind the gfx which though vastly improved I still need to tweak even more.. the sound alone is worth it and the non stuttering vulkan renderer is the icing on the cake. 1 Quote Link to comment Share on other sites More sharing options...
