No Connection
Rogue
RW Enhancer 2 was working fine yesterday got up to use it this morning and it will not connect.
States RW Central Connection State: Disconnected
Licence Key Not Provided
Error Unhandled Error  Normally it loads up and does the cooking thing and I can use it straight away any ideas about what is causing this?
Kind regards
Jason
Issue source is now identified and technical support has been contacted as the error is from Invision side, we can't do anything on our side.
This is the first major issue of the licensing system, thank you for your patience. Service should be fully restored during this afternoon. We will inform you about the problem resolution here.
Il y a 2 minutes , trainhunterHD a dit:
Same problem here. I think its related to latest update since i started having this issue right after the update
Not related to the latest update, the issue is on invision servers side so we are now waiting for the tech service of invision to fix the issue.
  • 1 month later...
